we already have the acqusition price and the depreciation in Value Model
What is the purpose for having the unit cost and quantity in the main fixed asset form ???
Where will the Ax use this field ? for calculation of depreciation ?? and can we leave it blank ???
Below explanation is from TechNet which gives you better understanding.
If an asset is not large enough to track on its own, you might group items together as one asset. For example, if you purchase 10 external hard drives for the Sales department, each external hard disk drive on its own is not large enough to track as an asset. However, the 10 hard drives together are an asset. In this example, type a quantity of 10 and define a unit of measure of Each. The unit cost of each external hard disk drive is 100, which gives the whole asset a value of 1,000.
It doesn’t have any significance but gives you information of how much quantity is considered as an asset. you can leave it blank.
Acquisition price in the value model will be considered for all the journal entries.
Santosh!
you nailed it!.. Good work:)
