Hi ,
What is the use of the additional qty field in the Unit conversion form in AX ?
Help Says : Qty added to the unit on conversion .
Please explain with an example and for which kind of material companies will use this functionality ?
Hi ,
Hi Lally,
see this form is for the calculation of quantities on the basis of units specified.
for example: if u create 1 box and want to use box as a quantity in Sales or Purchase, you have to define here how much units will a box contain of an item
like: 1 Box = 10 .
Still if you are confused please let me know about the scenario you are dealing with.
Trishant
I know the purpose of the Unit conversion form .
But i am not clear about the additional qty field , What is the use of the additional qty field in the Unit conversion form in AX ?
AX2009 I presume? It was to help with industries using reels and conversions down and an attempt to try and aggregate it (I believe). Not present in AX2012.
