I have a Doubt in financial dimension.
How to set the one main account set the two different type financial dimension its possible or not…
Pls help me.
samy.
Pls help me.
samy.
I think you need to give us an example of your problem to understand this.
hi
This
is Example
this main account is 2211001 this account is using two set financial dimension is here
single account but using two set of financial dimension .this dimension is appear in account based in AP Invoice.
S No. | Description | BU | DEPT. | LOB | CC-L1 | CC-L2 | CC-L3 | PC | PU | Main A/c |
1 | 1005 | 2000 | 3000 | 4007 | 5001 | 6000 | 7002 | 8000 | 2211001 |
2 | 1005 | 2000 | 3000 | 4001 | 5001 | 6000 | 7000 | 8000 | 2211001 |
This is possible using COA structures. Create the structure with Main account and ledger accounts. It’s always recommended to use main account and first component. Since BU, Dept and LOB is fixed, you can define fix values and for this, you can creaate combinations for remaining dimensions.
Pranav…
Hi Friends,
Please give me a full explanation for above content.
Samy.
