Can someone answer this pls-
I calculate FA Depreciation monthly and I setup posting profile
accordingly, will the system automatically post depreciation journal by end of each month, if yes what preset I should make to
allow AX to do this.
If you have set up the profiles and are calculating the depreciation why do you ask what “preset” you should make?
Try by adding the posting to the batch process…
