I have a question regarding DirParty Table. In DirParty Table, we can specify the first name, middle name and surname as well as Name Sequence (If it is a person), right? If I upload DirParty Table first, will it relate to the Vendor and Customer Master? Like having the same Name Sequence for the Vendor and Customer? I actually tried uploading the vendor and customer first, and then tried to update the name sequence by uploading the DirParty Table, but it just didn.t work. Did I miss something? How would I update the Name Sequence for Vendor/Customer?
There are many tables relating to the global address book becides DirPartyTable. Check in the AOT>Data Dictionary>Table Collections>DirPartyCollection for the GAB tables. What is a “Name Sequence”?
oh thanks Kranthi! I did not make the address book id the same for vendor and customer.
i uploaded the customer table first with no Name Sequence. So if I upload the Dirparty table next with my desired name sequence, the customer table that I previously uploaded will be updated with my desired Name sequence, correct? and if I uploaded the Vendor, it will have the same Name sequence if I copy the same Address book ID??
