here is the scenario…i select a JO no. which is a dimension…then select a vendor no…but then when i reselect a vendor the value of JO No. dimension disappears…is there a way not to make it disappear? by coding or setup maybe
Can’t say WHY, but Dims are fetched from Vendor Card, not Item - at least some of them… So, as you change Vendor, Dims are changed, too (VALIDATED actually).
Just did a quick check in CRONUS DB - Dims populated were values from VC. Well, Item in question hadn’t any Dims defined at all.
tried the default dimension function but the problem is when you change the JO. then select a vendor the value of JO will be the default of the item…the default value should be updated…is this possible?
