Hi I have a problem when configuration the connection betwen demand planner database and navisions database, I get this error: " The program failed to install integration stored procedures. Procedure details: /* * Syncronized Navision or Axapta with DP. Verify that the main_script.sql file in the application directory is not corrupted. " In the file includes the following text= 2004-03-24 09:52:45 ] : The program started successfully. [ 2004-03-24 09:55:01 ] : ------------- [ 2004-03-24 09:55:01 ] : Error: DPINT00104 CONNECTION_ERROR [ 2004-03-24 09:55:01 ] : Message: The program cannot connect to SQL Server. [ 2004-03-24 09:55:01 ] : Suggestion: Check that the server name and database name are correct and SQL Server is running. [ 2004-03-24 09:55:01 ] : Detail: Login failed for user ‘admin’. [ 2004-03-24 09:55:01 ] : Stack Trace: at System.Data.OleDb.OleDbConnection.ProcessResults(Int32 hr) at System.Data.OleDb.OleDbConnection.InitializeProvider() at System.Data.OleDb.OleDbConnection.Open() at BaseLib.BaseApplication.ConnectUntrusted(String serverName, String databaseName, String userId, String password, Error& err) [ 2004-03-24 09:55:01 ] : ------------- [ 2004-03-24 09:55:17 ] : ------------- [ 2004-03-24 09:55:17 ] : Error: DPINT00104 CONNECTION_ERROR [ 2004-03-24 09:55:17 ] : Message: The program cannot connect to SQL Server. [ 2004-03-24 09:55:17 ] : Suggestion: Check that the server name and database name are correct and SQL Server is running. [ 2004-03-24 09:55:17 ] : Detail: Login failed for user ‘Admin’. [ 2004-03-24 09:55:17 ] : Stack Trace: What is wrong?
Is there someone here who could tell me how he installed and configured demand planner correct?
The integration between Demand Planner and Navision run only on SQL. The integration use ODBC
What is demand planner. Is this an add on ? Or an interface to an external product. Where can I find out about demand planner.
Hi, Demand Planner is a tool provided by Microsoft (but developed in Italy) for Great Plains, Navision and Axapta. I can’t find anything official about the Navision implementation, but here is a general: http://www.microsoft.com/BusinessSolutions/Great%20Plains/Highlights/surplusshortfalls_demandplanner.mspx
