hi… I have a newbie question. i’m a navision developer and now i’m about to take a look at Axapta. i have installed SQL 2000 (default installation), and also installed application and axapta client… i have used the wizard to make a sql database … so far so good the problem is when i’m starting axapta… i get the following error message: Login failed for user TRSO. Reason: Not associated with a trusted SQL Server Connection. can anyone help me with this?? thanx in advance.
Hi First check if your SQL Server accepts only Windows authentication or SQL auth also. This must be switched on. Check in your Axapta configuration which sql user is specified. THis one should be db_owner.
thanx… works like a charm
