Hi
I want to migrate data(Master Vendor,customer,Item and Chart of Accounts) taken out from Axapta 2009 through Export wizard and inserted back to Axapta 2009 on another system or server.Please tell me the tables that i have to export from the older Axapta.And also please suggest me where this importing of data is right or later we face problem in transactions or i will put the data manually in the new system.
If you do not know the tables and do not know the issues and seeing manual creation as an option I would recommend you manually create the data.
These migrations have been discussed here many times, I would suggest you search the forum if you want further information.
hi thanks alot for replying
but it is very time taking to enter the master data, well i will read this in the forum also but if u get any solution plz let me know.
thanks…
imran ul haq
Where do the previous discussions not meet your needs or confuse you?
