you can customize the report to add additional periods…you will need some technical skills for it.
the PeriodStartDate,CustBalanceDue, etc variables’ dimension need to be increased, and their values extended in prereport, customer and integer dataitem sections.
you may even need to change the layout of report to accommodate additional columns.
