Im unable to delete customer records.
Im getting the below error when I try to delete the customer .
please guide.
Thanks & Regards,
Chutti
please guide.
Thanks & Regards,
Chutti
Hi Chutti,
This is a complete guess, but since we see code related to validating financial dimensions… do you have Customer enabled as a financial dimension?
I’m getting the same error when I’m trying to open the financial dimensions form from General ledger–> Setup–>Financial dimensions.
Thanks & Regards,
Chutti
I think you need to compile the Dimension related classes once and check if the problem is persisiting.
