Would like to know how to concatenate currency symbol with line amount?
ex: $ 1,254
i want the symbol next to the amount in reports… How to achieve this???
ex: $ 1,254
TextBuffer t;
str t1;
t=new TextBuffer();
t.setText(‘1254’); // you can use variable also like t.settext(variable_Name);
t.insert(’$’,0);
t1=t.getText();
// now t1 have a string value with prefix ‘$’ sign
verify the solution pls
Hello,
You can use very simple method;
Str value;
value = StrFmt(" %1 %2", CurrencySymbol,LineAmount );
or you can hardcode the value as
value = StrFmt(" $ %1", LineAmount );
or you can use num2str() to convert the real to string and concatnate with currency symbol;
Hope it will helps you.
there is another way to concatenate :
void conc()
str curr;
str lineAmount;
str concate;
concate=any2str(curr) + any2str(lineAmount)
// + operator is the simple way to concatenate i
i hope this sample of code help you
My Technical Blog: https://community.dynamics.com/product/ax/axtechnical/b/msdynamicsax2009abdelahmed/default.aspx?wa=wsignin1.0
if you need any help
