Concatenate string to numeric
I have a report that gets a field that is numeric from our database. I need to concatenate a dollar sign to it.
Display real disp_minlot()
return salesquotationline.pmf_AmountMinLotChg;
I just tried
return “$” + salesquotationline.pmf_AmountMinLotChg;
is there a ToString() function I can use to fuse the two?
I am using AX 4.0 and don’t have a lot of x++ experience
I tried
Display str disp_minlot()
return “$” + salesquotationline.pmf_AmountMinLotChg.ToString();
To no avail
You can’t call methods on primitive data types in X++ - it doesn’t have the magic of boxing like in C#. You can use num2str() instead, or strFmt(): strFmt("$%1", salesquotationline.pmf_AmountMinLotChg).
Nevertheless you should be careful with hard-coded formats - for example, many locales place currency signs behind amounts.
