Hi, Add the below method to the Global class - which will convert the number into Indian format
(or)
simply call the below method by passing the value.
static TempStr numeralsToTxt_IN(real _num)
//real _num = 2.315;
int numOfPennies = (decround(frac(_num), 2) * 100) mod 100;
real test = _num - frac(_num);
int numOfTenths;
str 20 ones[19], tenths[9], hundreds, thousands, lakhs, crores;
int64 temp;
str 200 returntxt;
str 200 pennytxt;
int penny;
real modOperator(real a1, real a2)
int tmpi;
real tmp1, tmp2;
tmp1 = a1 / a2;
tmpi = real2int(tmp1);
tmp2 = tmpi;
return (tmp1 - tmp2)*a2;
real checkPower(real _test, int64 _power)
int64 numOfPower;
if (_test >= _power)
numOfPower = _test div _power;
if (numOfPower >= 100)
temp = numOfPower div 100;
returntxt = returntxt + ’ ’ + ones[temp] + ’ ’ + hundreds;
numOfPower = numOfPower mod 100;
if (numOfPower >= 20)
temp = numOfPower div 10;
returntxt = returntxt + ’ ’ + tenths[temp];
numOfPower = numOfPower mod 10;
if (numOfPower >= 1)
returntxt = returntxt + ’ ’ + ones[numOfPower];
switch(_power)
case 10000000 :
returntxt = returntxt + ’ ’ + Crores;
_test = modOperator(_test, 10000000);
break;
case 100000 :
returntxt = returntxt + ’ ’ + lakhs;
_test = modOperator(_test, 100000);
break;
case 1000 :
returntxt = returntxt + ’ ’ + thousands;
_test = modOperator(_test, 1000);
break;
case 100 :
returntxt = returntxt + ’ ’ + hundreds;
_test = modOperator(_test, 100);
break;
return _test;
#Define.text_1(‘One’)
#Define.text_2(‘Two’)
#Define.text_3(‘Three’)
#Define.text_4(‘Four’)
#Define.text_5(‘Five’)
#Define.text_6(‘Six’)
#Define.text_7(‘Seven’)
#Define.text_8(‘Eight’)
#Define.text_9(‘Nine’)
#Define.text_10(‘Ten’)
#Define.text_11(‘Eleven’)
#Define.text_12(‘Twelve’)
#Define.text_13(‘Thirteen’)
#Define.text_14(‘Fourteen’)
#Define.text_15(‘Fifteen’)
#Define.text_16(‘Sixteen’)
#Define.text_17(‘Seventeen’)
#Define.text_18(‘Eighteen’)
#Define.text_19(‘Nineteen’)
#Define.text_20(‘Twenty’)
#Define.text_30(‘Thirty’)
#Define.text_40(‘Forty’)
#Define.text_50(‘Fifty’)
#Define.text_60(‘Sixty’)
#Define.text_70(‘Seventy’)
#Define.text_80(‘Eighty’)
#Define.text_90(‘Ninety’)
#Define.text_100(‘Hundred’)
#Define.text_1000(‘Thousand’)
#Define.text_100000(‘Lakh’)
#Define.text_10000000(‘Crore’)
#Define.text_and(‘Rupees and’)
#Define.text_paise(‘Paise Only’)
#Define.text_ruppe(‘Rupees Only’)
ones[1] = #text_1;
ones[2] = #text_2;
ones[3] = #text_3;
ones[4] = #text_4;
ones[5] = #text_5;
ones[6] = #text_6;
ones[7] = #text_7;
ones[8] = #text_8;
ones[9] = #text_9;
ones[10] = #text_10;
ones[11] = #text_11;
ones[12] = #text_12;
ones[13] = #text_13;
ones[14] = #text_14;
ones[15] = #text_15;
ones[16] = #text_16;
ones[17] = #text_17;
ones[18] = #text_18;
ones[19] = #text_19;
tenths[1] = ‘Not used’;
tenths[2] = #text_20;
tenths[3] = #text_30;
tenths[4] = #text_40;
tenths[5] = #text_50;
tenths[6] = #text_60;
tenths[7] = #text_70;
tenths[8] = #text_80;
tenths[9] = #text_90;
hundreds = #text_100;
thousands = #text_1000;
lakhs = #text_100000;
crores = #text_10000000;
test = checkPower(test, 10000000);
test = checkPower(test, 100000);
test = checkPower(test, 1000);
test = checkPower(test, 100);
if (test >= 20)
numOfTenths = test div 10;
returntxt = returntxt + ’ ’ + tenths[numofTenths];
numOfTenths = numOfTenths mod 10;
test = test mod 10;
if (test >= 1)
numOfTenths = real2int(test);
returntxt = returntxt + ’ ’ + ones[numOfTenths];
if (numOfPennies)
if (numOfPennies >= 20)
penny = numOfPennies div 10;
pennytxt = tenths[penny];
numOfPennies = numOfPennies mod 10;
if (numOfPennies >= 1)
pennytxt = pennytxt + ’ ’ + ones[numOfPennies];
returntxt = returntxt + ’ ’ + #text_and + ’ ’ + pennytxt + ’ ’ +#text_paise;
else
returntxt = returntxt + ’ ’ + #text_ruppe;
return returntxt;
// info(strfmt("%1",returntxt));
Manju [Y]
