digit convertion
how to convert amount of 100 into 000100 through code?
probably you can convert it into a string and concatenate
print ‘000’+ num2str(100,1,1,1,1);
Thanks Kranthi…:slight_smile:
Thanks Kranthi,
but what if the number will keep updating so it will generated together
example :-
100 = 000100
1000 = 001000
10000 = 010000
how to make it generate like this without having to put print ‘000’ at front ?
This is the easiest way:
num2str0(100, 6)
num2str0(1000, 6)
num2str0(10000, 6)
Thank you Martin
found the solution with your idea
heres what i did :-
amount = strReplace(num2str0(realno,12,2,0,0),".","");
result shown = 00000010000
thanks again
