I’m pretty new to Nav, even more so to RTC. Very happy I found this group!
I’m converting a customized Sales Order Subform from classic to RTC. In the form, some columns are made invisible based on a value set in the Sales Order header. This works fine in classic but not in RTC. The code conversion looks good but as I discovered from another user on this site, the visible property for the controls are evaluated only when the page is opened. Even if I set the visible variable I’m using as soon as the Sales Order document is opened, the OpenPage trigger fires in the subform before I get a chance to call my SetVisible function so the visible property never gets changed.
I was able to make this work on the Sales Order itself by adding the controls to a new group and setting the visible of that group. That works great. I tried the same thing with the subform but no joy.
I hope my description is clear enough. Any suggestions would be greatly appreciated.
You can control the visibility with a variable. So you would have a boolean called IsVisible, set the Visible property to IsVisible, and the set that variable in the code. I don’t if you will encounter the same problems as above, but the way I am describing doesn’t sound like the way the original poster did it.
Howdy! Never mind. I found out that you’ve got to go to the properties of the boolean variable, e.g.: ShowLineAmount and then change the property “IncludeInDataSet” to “Yes” and then it works 100%.
Sorry, I didn’t see your post before I posted again. What you say is what is normally done but this doesn’t work on a Subform Page. So what you say will only work if you set the “IncludeInDataset” property of the “IsVisible” variable to “Yes”.
