Dynamically hide/display fields in Report request page - NAV 2009 R2
Hi everyone,
I have to create a report with two fields in a request page : a boolean and a text field.
One of the requirements is that the text field in invisible when the user runs the report, It only gets visible if the boolean is checked by the user.
Is it possible in NAV 2009 R2? and how?
Thanks in advance :)
yes, it is possible and what did you try and what is not working?
sql or classic report ?
RTC report (request page [:)])
Hi Poppins,
You need to assign a boolean variable to the “visible” property of the control you like to hide.
Then you can assign the show/hide value to the variable in the OnOpenPage trigger.
Hi sir,
The identifier ‘Variable’ could not be found.
I am Learning how to NAV , am using Nav 2016. i hav tried what u said but it is giving error like above (created 2 variables 1st of boolean and 2nd text visibility of 2 nd variable is assigned with 1st in request page of report.
I Hopei will get reply soon ,
Raja
Did you set Include in dataset property of the boolean to yes?
yes i hav kept just now but not able to get Text variable as you validate the boolean variable.
with that Set Include in dataset removed error.[:D] .
Hi Mohana,
Just now i hav noticed that i can use editble property but unable to use Visible property
Can you attach the object (text version) to the post, then we can see why it doesn’t work?
OBJECT Report 55001 Customer by salesPerson1
OBJECT-PROPERTIES
Date=12/04/15;
Time=11:15:13 AM;
Modified=Yes;
Version List=;
PROPERTIES
DATASET
{ 1000000007;;DataItem; ;
DataItemTable=Table13;
OnAfterGetRecord=BEGIN
“Salesperson/Purchaser”.SETCURRENTKEY(“Salesperson/Purchaser”.Code);
END;
{ 1000000008;1;Column;Code_SalespersonPurchaser;
SourceExpr=“Salesperson/Purchaser”.Code }
{ 1000000009;1;Column;Name_SalespersonPurchaser;
SourceExpr=“Salesperson/Purchaser”.Name }
{ 1000000010;1;Column;Commission_SalespersonPurchaser;
SourceExpr=“Salesperson/Purchaser”.“Commission %” }
{ 1000000011;1;Column;CompanyInfo_Pic ;
SourceExpr=CompanyInformation.Picture }
{ 1000000000;1;DataItem; ;
DataItemTable=Table18;
OnPreDataItem=BEGIN
Customer.SETRANGE(“Salesperson Code”,“Salesperson/Purchaser”.Code);
Customer.SETFILTER(“Sales (LCY)”,’>0’);
END;
{ 1000000005;2;Column;SalespersonCode_Customer;
SourceExpr=Customer.“Salesperson Code” }
{ 1000000001;2;Column;No_Customer ;
SourceExpr=Customer.“No.” }
{ 1000000002;2;Column;Name_Customer ;
SourceExpr=Customer.Name }
{ 1000000003;2;Column;Address_Customer ;
SourceExpr=Customer.Address }
{ 1000000004;2;Column;City_Customer ;
SourceExpr=Customer.City }
{ 1000000006;2;Column;Sales ;
SourceExpr=Customer.“Sales (LCY)” }
REQUESTPAGE
PROPERTIES
OnInit=BEGIN
MESSAGE(‘Init’);
END;
OnOpenPage=BEGIN
MESSAGE(‘On Open’);
END;
OnClosePage=BEGIN
MESSAGE(‘On close’);
END;
CONTROLS
{ 1000000000;;Container;
Name=genenral;
CaptionML=ENU=Options;
ContainerType=ContentArea }
{ 1000000001;1;Field ;
Name=Boolean;
SourceExpr=BoolValue }
{ 1000000002;1;Field ;
Name=text;
SourceExpr=Textvalue;
Visible=BoolValue }
LABELS
CODE
VAR
CompanyInformation@1000000000 : Record 79;
null@1000000001 : Text;
BoolValue@1000000002 : Boolean INDATASET;
Textvalue@1000000003 : Text;
opt@1000000004 : Text;
window1@1000000005 : DotNet “‘Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’.Microsoft.VisualBasic.Interaction”;
window@1000000006 : Dialog;
BEGIN
END.
RDLDATA
<?xml version="1.0" encoding="utf-8"?>
0
SQL
rd:DataSourceID27a28329-09ae-4350-b2e6-eed7bff71f70</rd:DataSourceID>
DataSource
No_Customer
Name_Customer
Address_Customer
City_Customer
Sales
SalesFormat
Commission_SalespersonPurchaserFormat
CompanyInfo_Pic
rd:DataSetInfo
rd:DataSetNameDataSet</rd:DataSetName>
rd:SchemaPathReport.xsd</rd:SchemaPath>
rd:TableNameResult</rd:TableName>
</rd:DataSetInfo>
1in
1in
1in
1in
1in
1in
0.25in
true
true
Name
Textbox13 LightGrey Solid
2pt
2pt
2pt
2pt
true
true
No Customer
Textbox3 LightGrey Solid
2pt
2pt
2pt
2pt
true
true
Name Customer
Textbox5 LightGrey Solid
2pt
2pt
2pt
2pt
true
true
City Customer
Textbox9 LightGrey Solid
2pt
2pt
2pt
2pt
true
true
Sales
Textbox11 LightGrey Solid
2pt
&n
http://dynamicsuser.net/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.19.66.02/Dynamic-Request-pagetxt.txt
this is my text file sir sorry at first i wasn’t able to uploaddue to site technical reasons then came to know how to overcome …
Raja,
You’re not assigning any value to your BoolValue variable. Do this in OnOpenPage.
Hi Sir(Erik P. Ernst),
what i want is dynamically change the hide/display fields in request page . if i hardcode value in Boolean
variable then my fields will be either permanently visible/ Permanently Invisible . I am Not able to take from window .INPUT();… So, Can we Achieve it? if Yes , How ?
I am Looking Forward for your Reply…[Y]
hi Everyone,
At Last got answer from my Seniors , (Mahesh U) that in NAV 2015,2016 we are not able to change the visibility of request page fields . INstead of that we can achieve this by defining them in another group and group visibity can be
Modified at Runtime/Dynamically display fields in request Page.
Thanks to everyone …who helped me .Mohana,****Erik P. Ernst,uppala mahesh,ramesh
