When i tried to login AX, It shown the screen like service is down. When i checked services, it have stopped and not running. Then i have tried to restart the service(MS dynamics AX object server) it shows the below error.
When i check the Event logger i got the below errors,
is there any changes in network or server side recently?
check if your aos service account has proper rights to open the sql server ,
ping sql server from aos server
check if your aos service account’s password is not expired.
Hi Kunal,
The ping happened from AOS server to DB server perfectly.
Is that a problem with AOS service logon account. If it is yes then kindly let us know how to resolve the same.
