I m doing Upgrade Project From AX-4.0 to AX-2009
I have completed my code upgrade.
While doing data Upgrade I have done my pre synchronization with 100%
Syncronization also completed with some warning and info.
But while running the post synchronization i cant able to complete. It is getting struck to one of the job and it is not getting completed even i left it for 2 days also
Ya but after 2 days if i cancle the status and run the post synchronization again the it is completing with 100%…
I m using windows server operating system R2 with service pack 2 and SQL-2005 , AX-2009 , Ax-update, and India Localization
What job does it get stuck on? And I remember having the same issue where jobs would hang and create SQL locks I think, then I would just cancel and re-try and it would work. You are probably fine. Find the job that is hanging, look in the classes\ReleaseUpdateDB41* stuff and see what steps it is actually performing if you want to verify.
