I m doing Upgrade Project From AX-4.0 to AX-2009
I have completed my code upgrade.
While doing data Upgrade I have done my pre synchronization with 100%
Syncronization also completed with some warning and info.
But while running the post synchronization i cant able to complete. It is getting struck to one of the job and it is not getting completed even i left it for 2 days also
Ya but after 2 days if i cancle the status and run the post synchronization again the it is completing with 100%…
I m using windows server operating system R2 with service pack 2 and SQL-2005 , AX-2009 , Ax-update, and India Localization
Hi sir there is no error.This job is in executing state…even if i left it for 2 days also. But if i cancle the post synchronization after 2 days and run it again then it is completing 100%.
The job is as follow:
Updating InvoiceRefRecId of the table SalesLine with the corresponding Recid of the table CustInvoiceTrans. (this job is in executing state)
The upgrade jobs can be finicky. Are you able to actually cancel the executing job? If you cancel it, it should list it as a failed job, and you should be able to re-run the failed jobs only.
