I am getting this error while installing client of AX 2009, the “32 bit component” installation window just rolls back after sometime. Surprisingly for other 2 machines it got installed those machines have same config and same domain rights. Here XX is username and ABCD is the company name.
=== Setup logging started: 01/12/1431 09:27:53 ص ===
Running file: “C:\DOCUME~1\XXX~1\LOCALS~1\Temp\AxSetup\AxSetup.exe” RelatedFilesDir=“\XX\Shared\AX 2009\DynamicsAX2009”
AxSetup version number: 5.0.593.0
Microsoft Windows NT 5.1.2600 Service Pack 2 (32 bit)
CB125-IPC08WI
ABCD\XXXisi
Interactive: True
RelatedFilesDir=\XX\Shared\AX 2009\DynamicsAX2009
Property RelatedFilesDir set to: '\XX\Shared\AX 2009\DynamicsAX2009'
Property SetupLanguage set to: ‘EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-11-07 09-27-53\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
MSI file: Components32.msi Installed: False
MSI file: ClientHelp.msi Installed: False
=== Checking parameters ===
Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property AcceptLicenseTerms set to: ‘1’
Property BypassWarnings set to: ‘0’
Property RunMode set to: ‘Custom’
Property InstallClientUI set to: ‘1’
Performing prerequisite validation: VC++ SP1
Installing Microsoft Visual C++ 2008 Redistributable
See C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-11-07 09-27-53\VisualC2008Log.txt for additional informational messages.
\XX\Shared\AX 2009\DynamicsAX2009\Redist\VisualC2008\vcredist_x86.exe /qb! /l C:\DOCUME~1\ALLUSE~1\APPLIC~1\MICROS~1\DYNAMI~1\DYNAMI~1\2010-1~1\VISUAL~1.TXT
Property ConfigurePrerequisites set to: ‘1’
Property ClientLanguage set to: ‘EN-US’
Property ClientHelpLanguages set to: ‘EN-US’
Property ClientAosServer set to: ‘10.241.16.57’
Property AosInstanceName set to: ‘’
Property AosPort set to: ‘2712’
=== Starting execution phase ===
=== Setting up Components ===
Launching MSI: /i “\XX\Shared\AX 2009\DynamicsAX2009\Msi\Components32\Components32.msi” /qb-! /l*v “C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-11-07 09-27-53\Components32 Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files\Microsoft Dynamics AX\50” ADDLOCAL=“ClientUI,ClientConfig”
An error occurred during setup of Components.
For more information see: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-11-07 09-27-53\Components32 Log.txt
Additional information may be available in the InstallLog files under: C:\Program Files\Microsoft Dynamics AX\50\Setup
Following are messages from the MSI actions log file Microsoft.Dynamics.Setup.Components.InstallLog, which could include earlier messages, (check the date):
Installing assembly ‘C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Components.dll’.
Affected parameters are:
setuplanguage = EN
action = install
clientbindir = C:\Program Files\Microsoft Dynamics AX\50\Client\Bin#
feature = ClientUI
installtype = notransaction
assemblypath = C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Components.dll
logfile = C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Components.InstallLog
Install: العميل Start 01/12/1431 09:32:04 ص
Install: Unregistering file ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.dll” /unregister
Install: Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.3053
Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
Types un-registered successfully
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.dll” /tlb /codebase
Types registered successfully
Assembly exported to ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.tlb’, and the type library was registered successfully
Install: Unregistering file ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ElsterTransferHandler.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ElsterTransferHandler.dll” /unregister
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ElsterTransferHandler.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ElsterTransferHandler.dll” /tlb /codebase
Assembly exported to ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ElsterTransferHandler.tlb’, and the type library was registered successfully
Install: Unregistering file ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.dll” /unregister
RegAsm : error RA0000 : An error occurred inside the user defined Register/Unregister functions: System.ArgumentException: Cannot delete a subkey tree because the subkey does not exist.
at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at Microsoft.Win32.RegistryKey.DeleteSubKeyTree(String subkey)
at Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.ComUnregister(Type t)
Install: During Setup of an error occurred. Program run: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe. Parameters: “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.dll” /unregister
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.dll” /tlb /codebase
Assembly exported to ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.Expression.AxExpressionBuilder.tlb’, and the type library was registered successfully
Install: Unregistering file ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.DirectoryView.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.DirectoryView.dll” /unregister
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.DirectoryView.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.DirectoryView.dll” /tlb /codebase
Type library exporter warning processing ‘Microsoft.Dynamics.Framework.DirectoryView.IDirPartyDirectoryNode, Microsoft.Dynamics.Framework.DirectoryView’. Warning: The type had one or more duplicate DISPIDs specified. The duplicate DISPIDs were ignored.
Assembly exported to ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.Framework.DirectoryView.tlb’, and the type library was registered successfully
Install: Unregistering file ‘C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll” /unregister
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll’
Install: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.dll” /tlb /codebase
Assembly exported to ‘C:\Program Files\Microsoft Dynamics AX\Common\MindKeyGroup.MindKey.Wheel.tlb’, and the type library was registered successfully
Install: Configuring Client Performance Counters
Install: mofcomp “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\ax_trace.mof”
Install: Microsoft (R) 32-bit MOF Compiler Version 5.1.2600.2180
Copyright (c) Microsoft Corp. 1997-2001. All rights reserved.
Parsing MOF file: C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\ax_trace.mof
MOF file has been successfully parsed
Storing data in the repository…
Done!
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\smmphone.ocx’
Install: regsvr32 “C:\Program Files\Microsoft Dynamics AX\Common\smmphone.ocx” /s
Install:
Install: C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\ax32.exe -regserver
Install:
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\vcgantt.ocx’
Install: regsvr32 “C:\Program Files\Microsoft Dynamics AX\Common\vcgantt.ocx” /s
Install:
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\drop2ctrl.ocx’
Install: regsvr32 “C:\Program Files\Microsoft Dynamics AX\Common\drop2ctrl.ocx” /s
Install:
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\AxHelpCtrl.dll’
Install: regsvr32 “C:\Program Files\Microsoft Dynamics AX\Common\AxHelpCtrl.dll” /s
Install:
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\WheelAx.dll’
Install: regsvr32 “C:\Program Files\Microsoft Dynamics AX\Common\WheelAx.dll” /s
Install:
Install: Registering or configuring file: ‘C:\Program Files\Microsoft Dynamics AX\Common\AnaMeter.dll’
Install: regsvr32 “C:\Program Files\Microsoft Dynamics AX\Common\AnaMeter.dll” /s
Install:
Install: العميل End 01/12/1431 09:32:39 ص
Rolling back assembly ‘C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Components.dll’.
setuplanguage = EN
action = rollback
feature = ClientUI
Rollback: العميل Start 01/12/1431 09:32:48 ص
Rollback: Attempting to remove Client which may have been partially or fully installed
Rollback: Unregistering file ‘C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.dll’
Rollback: C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\regasm.exe “C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.ReportingServices.dll” /unregister
Rollback: Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.3053
Rollback: C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\ax32.exe -unregserver
Rollback:
Rollback: Removing Client Performance Counters
Rollback: العميل End 01/12/1431 09:32:50 ص
=== Setup was canceled or failed. For details see the previous messages in the log.
=== Setup logging ended: 01/12/1431 09:35:15 ص ErrorLevel/ExitCode: ‘1’ ===
