=== Setup logging started: 12/31/2010 5:59:57 AM ===
Running file: “C:\DOCUME~1\SKESAR~1\LOCALS~1\Temp\3\AxSetup\AxSetup.exe” RelatedFilesDir=“E:”
AxSetup version number: 5.0.593.0
Microsoft Windows NT 5.2.3790 Service Pack 2 (32 bit)
AXAPTA09TS
DEMO\skesarwani
Interactive: True
RelatedFilesDir=E:
Property RelatedFilesDir set to: 'E:'
Property SetupLanguage set to: ‘EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-12-31 05-59-57\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
Application Object Server instance 1 has been installed with the name 01-DEMO_AX2009_SP1_AOS_Stadard.
MSI file: Components32.msi Installed: True
MSI file: ClientHelp.msi Installed: True
Property ClientHelpLanguages set to: ‘EN-US;EN-GB’
Previously Installed Component: Application Object Server (AOS) (01-DEMO_AX2009_SP1_AOS_Stadard)
Previously Installed Component: Client
Previously Installed Component: Role Centers and Enterprise Portal
Previously Installed Component: .NET Business Connector
Previously Installed Component: Debugger
Previously Installed Component: Enterprise Portal developer tools
Property RunMode set to: ‘AddRemoveFeatures’
=== Checking parameters ===
Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property RemoveComponents set to: ‘0’
Property BypassWarnings set to: ‘0’
Entering method GetBusinessConnectorProxyAccount
The API return value is demo.local\sKesarwani.
Leaving method GetBusinessConnectorProxyAccount
Entering method IsRunningMode
The API return value is True.
Leaving method IsRunningMode
Entering method GetWorkflowSystemDomainAccount
Retrieving workflow system account.
Leaving method GetWorkflowSystemDomainAccount
The return value from this method is ‘demo.local\WFSys’.
Property InstallWorkflow set to: ‘1’
Property BusinessConnectorProxyAccount set to: ‘DEMO\skesarwani’
Property BusinessConnectorProxyAccountPassword set to: ‘**********’
Entering method GetIisWebSitesOnTheLocalSystem
Retrieving the list of Web sites on this system
Entering method GetNamesOfAllWebSites
Leaving method GetNamesOfAllWebSites
The return value from this method is ‘1,1121112642,1653210679,2,1920642717’.
Entering method GetFriendlyNameOfWebSite
The input parameters to this method are: ‘1’
Entering method GetWebSite
Leaving method GetWebSite
The return value from this method is ‘1’.
Leaving method GetFriendlyNameOfWebSite
The return value from this method is ‘Default Web Site’.
The input parameters to this method are: ‘1121112642’
The return value from this method is ‘1121112642’.
The return value from this method is ‘SharePoint Central Administration v3’.
The input parameters to this method are: ‘1653210679’
The return value from this method is ‘1653210679’.
The return value from this method is ‘SharePoint - 80’.
The input parameters to this method are: ‘2’
The return value from this method is ‘2’.
The return value from this method is ‘Microsoft SharePoint Administration’.
The input parameters to this method are: ‘1920642717’
The return value from this method is ‘1920642717’.
The return value from this method is ‘MicrosoftDynamicsAXWorkflow50_1’.
Entering method GetLoggableNamesOfWebSites
The input parameters to this method are: ‘Microsoft.Dynamics.Setup.IisWebSite:5’
Leaving method GetLoggableNamesOfWebSites
The return value from this method is ‘Default Web Site (1),SharePoint Central Administration v3 (1121112642),SharePoint - 80 (1653210679),Microsoft SharePoint Administration (2),MicrosoftDynamicsAXWorkflow50_1 (1920642717)’.
The list of Web sites are ‘Default Web Site (1), SharePoint Central Administration v3 (1121112642), SharePoint - 80 (1653210679), Microsoft SharePoint Administration (2), MicrosoftDynamicsAXWorkflow50_1 (1920642717)’.
Leaving method GetIisWebSitesOnTheLocalSystem
Entering method CheckForWorkflowSetupConfigurationNameClashes
The input parameters to this method are: ‘MicrosoftDynamicsAXWorkflow50_1’
Checking for availability of names for Workflow setup
Entering method DoesVirtualDirExist
The input parameters to this method are: ‘MicrosoftDynamicsAXWorkflow50,1920642717’
Entering method GetVirtualDir
Entering method GetRootVirtualDirMetabasePath
Leaving method GetRootVirtualDirMetabasePath
The return value from this method is ‘IIS://localhost/W3SVC/1920642717/Root’.
Leaving method GetVirtualDir
The return value from this method is ‘null’.
Leaving method DoesVirtualDirExist
The return value from this method is ‘False’.
Checking whether a Workflow virtual directory already exists with this name: The required name is not in use.
Entering method DoesAppPoolExist
The input parameters to this method are: ‘MicrosoftDynamicsAXWorkflow50’
Entering method GetAppPool
Leaving method GetAppPool
Leaving method DoesAppPoolExist
Checking whether an application pool already exists with this name: The required name is not in use.
Leaving method CheckForWorkflowSetupConfigurationNameClashes
The return value from this method is ‘None’.
Property WorkflowWebSite set to: ‘MicrosoftDynamicsAXWorkflow50_1’
Property WorkflowAosAccounts set to: ‘NT AUTHORITY\NETWORK SERVICE’
Property ResetIIS set to: ‘1’
=== Starting execution phase ===
=== Setting up ASP.NET 2.0 ===
Configuring the .NET Framework ASP.Net for IIS
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i -enable
Start installing ASP.NET (2.0.50727).
Finished installing ASP.NET (2.0.50727).
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -sn W3SVC
Start registering ASP.NET scriptmap (2.0.50727) at W3SVC.
Finished registering ASP.NET scriptmap (2.0.50727) at W3SVC.
=== Setting up Components ===
Launching MSI: /i “E:\Msi\Components32\Components32.msi” /qb-! /l*v “C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-12-31 05-59-57\Components32 Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files\Microsoft Dynamics AX\50” ADDLOCAL=“ClientUI,EnterprisePortal,NetBusinessConnector,Debugger,EnterprisePortalTools,Workflow,ClientConfig”
Following are messages from the MSI actions log file Microsoft.Dynamics.Setup.Workflow.InstallLog, which could include earlier messages, (check the date):
Uninstalling assembly ‘C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Workflow.dll’.
Affected parameters are:
action = uninstall
rollbackfaileduninstall =
installtype = notransaction
assemblypath = C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Workflow.dll
logfile = C:\Program Files\Microsoft Dynamics AX\50\Setup\Microsoft.Dynamics.Setup.Workflow.InstallLog
Uninstall: Workflow Start 12/31/2010 3:30:44 AM
Uninstall: Entering method GetIisWebSitesOnTheLocalSystem
Uninstall: Retrieving the list of Web sites on this system
Uninstall: Entering method GetNamesOfAllWebSites
Uninstall: Leaving method GetNamesOfAllWebSites
Uninstall: The return value from this method is ‘1,1121112642,1653210679,2’.
Uninstall: Entering method GetFriendlyNameOfWebSite
Uninstall: The input parameters to this method are: ‘1’
Uninstall: Entering method GetWebSite
Uninstall: Leaving method GetWebSite
Uninstall: The return value from this method is ‘1’.
Uninstall: Leaving method GetFriendlyNameOfWebSite
Uninstall: The return value from this method is ‘Default Web Site’.
Uninstall: The input parameters to this method are: ‘1121112642’
Uninstall: The return value from this method is ‘1121112642’.
Uninstall: The return value from this method is ‘SharePoint Central Administration v3’.
Uninstall: The input parameters to this method are: ‘1653210679’
Uninstall: The return value from this method is ‘1653210679’.
Uninstall: The return value from this method is ‘SharePoint - 80’.
Uninstall: The input parameters to this method are: ‘2’
Uninstall: The return value from this method is ‘2’.
Uninstall: The return value from this method is ‘Microsoft SharePoint Administration’.
Uninstall: Entering method GetLoggableNamesOfWebSites
Uninstall: The input parameters to this method are: ‘Microsoft.Dynamics.Setup.IisWebSite:4’
Uninstall: Leaving method GetLoggableNamesOfWebSites
Uninstall: The return value from this method is ‘Default Web Site (1),SharePoint Central Administration v3 (1121112642),SharePoint - 80 (1653210679),Microsoft SharePoint Administration (2)’.
Uninstall: The list of Web sites are ‘Default Web Site (1), SharePoint Central Administration v3 (1121112642), SharePoint - 80 (1653210679), Microsoft SharePoint Administration (2)’.
Uninstall: Leaving method GetIisWebSitesOnTheLocalSystem
Uninstall: Entering method Deconfigure
Uninstall: The input parameters to this method are: ‘Default Web Site’
Uninstall: Reversing the changes made during Workflow setup
Uninstall: Entering method DoesVirtualDirExist
Uninstall: The input parameters to this method are: ‘MicrosoftDynamicsAXWorkflow50,1’
Uninstall: Entering method GetVirtualDir
Uninstall: Entering method GetRootVirtualDirMetabasePath
Uninstall: Leaving method GetRootVirtualDirMetabasePath
Uninstall: The return value from this method is ‘IIS://localhost/W3SVC/1/Root’.
Uninstall: Leaving method GetVirtualDir
Uninstall: The return value from this method is ‘null’.
Uninstall: Leaving method DoesVirtualDirExist
Uninstall: The return value from this method is ‘False’.
Uninstall: Setup could not detect Workflow virtual directory ‘MicrosoftDynamicsAXWorkflow50’.
Uninstall: Entering method DoesAppPoolExist
Uninstall: The input parameters to this method are: ‘MicrosoftDynamicsAXWorkflow50’
Uninstall: Entering method GetAppPool
Uninstall: Leaving method GetAppPool
Uninstall: Leaving method DoesAppPoolExist
Uninstall: Setup could not detect the Workflow application pool ‘MicrosoftDynamicsAXWorkflow50’.
Uninstall: Leaving method Deconfigure
Uninstall: The return value from this method is ‘None’.
Uninstall: Workflow End 12/31/2010 3:30:44 AM
Starting configuration of Workflow
Entering method SetBCProxyAccountInAxapta
The API input parameter is DEMO\skesarwani.
Entering method UpdateBusinessConnectorProxyAccount
An error has occured while Setup was establishing a connection through Business Connector. Error: Dynamics Adapter CallStaticClassMethod failed.
Leaving method UpdateBusinessConnectorProxyAccount
An error occurred during setup of Workflow.
Reason: An error has occured while Setup was establishing a connection through Business Connector. Error: Dynamics Adapter CallStaticClassMethod failed.
Workflow was left in a partially installed state. Review the log messages to determine whether you can manually finish the installation. If not, then you need to: 1) Rerun Setup and choose the option to remove Workflow. 2) Correct the system problem that caused the error. 3) Rerun Setup and install Workflow again.
=== Rolling back setup of Workflow due to error ===
Launching MSI: /i “E:\Msi\Components32\Components32.msi” /qb-! /l*v “C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2010-12-31 05-59-57\Components32 Rollback Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files\Microsoft Dynamics AX\50” ADDLOCAL=“ClientUI,EnterprisePortal,NetBusinessConnector,Debugger,EnterprisePortalTools,Workflow,ClientConfig” REMOVE=“Workflow”
Rollback of === Rolling back setup of Workflow due to error ===
installation has been completed. For details about why the installation failed, see the previous messages in the log.
=== Setup was canceled or failed. For details see the previous messages in the log.
=== Setup logging ended: 12/31/2010 6:02:28 AM ErrorLevel/ExitCode: ‘1’ ===
