i am a newbie in ax i am installing ax on ms 2003 r2 standard edn and i haveinstalled sql server 2005 sp2
I have added exception to firewall for port 2712 on the local machine.When i start my instalation i select the developer installation and for the AOS service i am using Network service insted of domain account. Mydatabase is created success fuly Applaiction Files are installed successfull but i get error in AOS
below is the error from the log…
ANY HELP appreciated Thanks in advance
=== Setup logging started: 22/11/2011 2:43:57 PM ===
Running file: “C:\DOCUME~1\ADMINI~1.ARR\LOCALS~1\Temp\AxSetup\AxSetup.exe” RelatedFilesDir=“D:\ax2009”
AxSetup version number: 5.0.593.0
Microsoft Windows NT 5.2.3790 Service Pack 2 (32 bit)
DUNDAS
ARRIYADHHOLDING\administrator
Interactive: True
RelatedFilesDir=D:\ax2009
Property RelatedFilesDir set to: ‘D:\ax2009’
Property SetupLanguage set to: ‘EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-11-22 14-43-57\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
MSI file: Components32.msi Installed: False
MSI file: ClientHelp.msi Installed: False
=== Checking parameters ===
Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property AcceptLicenseTerms set to: ‘1’
Property BypassWarnings set to: ‘0’
Property RunMode set to: ‘DeveloperComponents’
Property InstallAnalysisServicesExtensions set to: ‘0’
Property InstallAos set to: ‘1’
Property ClientAosServer set to: ‘DUNDAS’
Property InstallApplication set to: ‘1’
Property InstallAifWebServices set to: ‘0’
Property InstallBizTalkAdapter set to: ‘0’
Property InstallClientUI set to: ‘1’
Property InstallComBusinessConnector set to: ‘0’
Property InstallDatabase set to: ‘1’
Property InstallEnterprisePortal set to: ‘0’
Property InstallNetBusinessConnector set to: ‘1’
Property InstallDebugger set to: ‘1’
Property InstallEnterprisePortalTools set to: ‘0’
Property InstallReportingServicesExtensions set to: ‘0’
Property InstallReportingTools set to: ‘0’
Property InstallSynchronizationProxy set to: ‘0’
Property InstallSynchronizationService set to: ‘0’
Property InstallWorkflow set to: ‘0’
Property DbServerType set to: ‘0’
Performing prerequisite validation: VC++ SP1
Performing prerequisite validation: SNAC
Property DbSqlServer set to: ‘DUNDAS’
Connected to SQL Server: ‘DUNDAS’
Property DbSqlDatabaseName set to: ‘DynamicsAx1’
Property ApplicationInstanceName set to: ‘DynamicsAx1’
Property ApplicationRegion set to: ‘-’
Property AosPort set to: ‘2712’
Property AosInstanceName set to: ‘DynamicsAx1’
Property AosReportErrors set to: ‘0’
The localized name for the NT Authority\Network Service account has been identified as ‘NT AUTHORITY\NETWORK SERVICE’.
Property AosAccount set to: ‘’
Property ClientLanguage set to: ‘EN-US’
Property ClientHelpLanguages set to: ‘EN-US’
Property AosStart set to: ‘1’
=== Starting execution phase ===
=== Setting up Database DynamicsAx1 ===
isolation level = read committed
ALTER DATABASE [DynamicsAx1] SET READ_COMMITTED_SNAPSHOT ON
Completed setup of Database DynamicsAx1.
=== Setting up Application files ===
Completed setup of Application files.
=== Setting up Application Object Server (AOS) ===
Adding account ‘ARRIYADHHOLDING\DUNDAS$’ as a login in Microsoft SQL Server.
isolation level = read committed snapshot
Property AosApplicationPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
Setting up rights for the AOS service account ‘NT AUTHORITY\NETWORK SERVICE’ to access the application files at: C:\Program Files\Microsoft Dynamics AX\50\Application
The localized name for the BUILTIN\USERS account has been identified as ‘BUILTIN\Users’.
Launching MSI: /i “D:\ax2009\Msi\ObjectServer32\ObjectServer32.msi” /qb-! /l*v “C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-11-22 14-43-57\ObjectServer32 Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN TRANSFORMS=:Instance01 MSINEWINSTANCE=1 INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50\Server” AOSSTART=“1” AOSACCOUNTPASSWORD="" BYPASSWARNINGS=“0”
An error occurred during setup of Application Object Server (AOS).
For more information see: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-11-22 14-43-57\ObjectServer32 Log.txt
Additional information may be available in the InstallLog files under: C:\Program Files\Microsoft Dynamics AX\50\Setup
=== Setup was canceled or failed. For details see the previous messages in the log.
=== Setup logging ended: 22/11/2011 2:49:14 PM ErrorLevel/ExitCode: ‘1’ ===
