Hi this is Nagendra, I am functional consultant. I am trying to install Dynamics ax install in my laptop. System throwing error check the logs while AOS installation time. Any body please help me to install Dynamics.
Sql server 2008 installed and using win 7
Log file:
=== Setup logging started: 14-Nov-13 11:15:25 PM ===
Running file: “C:\Users\krishan\AppData\Local\Temp\AxSetup\AxSetup.exe” RelatedFilesDir=“E:\Microsoft-Dynamics-AX-2009-Full\DynamicsAX2009”
AxSetup version number: 5.0.593.0
Microsoft Windows NT 6.1.7601 Service Pack 1 (32 bit)
VENKY
VENKY-PC\krishan
Interactive: True
RelatedFilesDir=E:\Microsoft-Dynamics-AX-2009-Full\DynamicsAX2009
Property RelatedFilesDir set to: ‘E:\Microsoft-Dynamics-AX-2009-Full\DynamicsAX2009’
Property SetupLanguage set to: ‘EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2013-11-14 23-15-25\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
MSI file: Components32.msi Installed: False
MSI file: ClientHelp.msi Installed: False
=== Checking parameters ===
Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property AcceptLicenseTerms set to: ‘1’
Property BypassWarnings set to: ‘0’
Property RunMode set to: ‘Custom’
Property InstallDatabase set to: ‘1’
Property InstallApplication set to: ‘1’
Setup has detected that you are installing Application Object Server (AOS) on an operating system that is not supported for Microsoft Dynamics AX.
The minimum supported server operating system is Microsoft Windows Server 2003 with Service Pack 2.
Property InstallAos set to: ‘1’
Property ClientAosServer set to: ‘VENKY’
Property InstallClientUI set to: ‘1’
Property InstallAos set to: ‘0’
Property InstallDebugger set to: ‘1’
Property InstallReportingTools set to: ‘1’
Property InstallNetBusinessConnector set to: ‘1’
Setup has detected that you are installing Analysis extensions on an operating system that is not supported for Microsoft Dynamics AX.
Property DbServerType set to: ‘0’
Performing prerequisite validation: DhtmlEd
Performing prerequisite validation: VC++ SP1
Performing prerequisite validation: SNAC
Property DbSqlServer set to: ‘VENKY’
Connected to SQL Server: ‘VENKY’
Property DbSqlDatabaseName set to: ‘DynamicsAx1’
Property DbSqlDatabaseName set to: ‘DynamicsAx2’
Property ApplicationInstanceName set to: ‘DynamicsAx2’
Property ApplicationRegion set to: ‘-’
Property AosPort set to: ‘2712’
Property AosInstanceName set to: ‘DynamicsAx2’
Property AosReportErrors set to: ‘0’
The localized name for the NT Authority\Network Service account has been identified as ‘NT AUTHORITY\NETWORK SERVICE’.
Property AosAccount set to: ‘’
Property ClientLanguage set to: ‘EN-US’
Property ClientHelpLanguages set to: ‘EN-US’
Property AosStart set to: ‘1’
=== Starting execution phase ===
=== Setting up Database DynamicsAx2 ===
isolation level = read committed
ALTER DATABASE [DynamicsAx2] SET READ_COMMITTED_SNAPSHOT ON
Completed setup of Database DynamicsAx2.
=== Setting up Application files ===
Completed setup of Application files.
=== Setting up Application Object Server (AOS) ===
Exception: System.Management.ManagementException
Message: Not found
FullText: System.Management.ManagementException: Not found
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Get()
at Microsoft.Dynamics.Setup.Misc.GetMachineDomain()
at Microsoft.Dynamics.Setup.Misc.GetMachineAccountName()
at Microsoft.Dynamics.Setup.InstallSqlServer.GrantAosAccessToRemoteSqlServer()
at Microsoft.Dynamics.Setup.InstallSqlServer.GrantAosAccess()
at Microsoft.Dynamics.Setup.MainForm.AosDbAccess()
at Microsoft.Dynamics.Setup.MainForm.s250Timer_Tick()
==== Setup encountered an unhandled exception and could not be completed. For details see the previous messages in the log. ===
