I am trying to install AX 2009 development system and am facing problem while installing reporting tools.
i have installed EP and role center and Reporting service but when u try to install reporting tools it show the following error
Please Help me out here its really breaking my head out since one week.
This is the error am getting in log.txt…
=== Setup logging started: 8/8/2012 4:46:12 PM ===
Running file: “C:\Users\ADMINI~1\AppData\Local\Temp\AxSetup\AxSetup.exe” RelatedFilesDir="\ip address\Users\user\Desktop\Microsoft Dynamics AX 2009 - SP1 -Installable"
AxSetup version number: 5.0.593.0
Microsoft Windows NT 6.1.7600.0 (64 bit)
LOCUSIT
AXDOMAIN\Administrator
Interactive: True
RelatedFilesDir=\ip address\Users\user\Desktop\Microsoft Dynamics AX 2009 - SP1 -Installable
Property RelatedFilesDir set to: ‘\ip address\Users\user\Desktop\Microsoft Dynamics AX 2009 - SP1’
Property SetupLanguage set to: ‘EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2012-08-08 16-46-12\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
Application Object Server instance 1 has been installed with the name 01-AXapplicationInstance.
MSI file: Components64.msi Installed: True
MSI file: ClientHelp.msi Installed: True
Property ClientHelpLanguages set to: ‘EN-US;EN-IN’
Previously Installed Component: Application Object Server (AOS) (01-AXapplicationInstance)
Previously Installed Component: Client
Previously Installed Component: Role Centers and Enterprise Portal
Previously Installed Component: .NET Business Connector
Previously Installed Component: Reporting extensions
Property RunMode set to: ‘AddRemoveFeatures’
=== Checking parameters ===
Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
Property InstallPath32Bit set to: ‘C:\Program Files (x86)\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property RemoveComponents set to: ‘0’
Property BypassWarnings set to: ‘0’
Property InstallReportingTools set to: ‘1’
=== Starting execution phase ===
=== Setting up Components ===
Launching MSI: /i “\ ip address \Users\user\Desktop\Microsoft Dynamics AX 2009 - SP1 \Msi\Components64\Components64.msi” /qb-! /l*v “C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2012-08-08 16-46-12\Components64 Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files (x86)\Microsoft Dynamics AX\50” ADDLOCAL=“ClientUI,EnterprisePortal,NetBusinessConnector,ReportingServicesExtensions,ReportingTools,ClientConfig”
An error occurred during setup of Components.
For more information see: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2012-08-08 16-46-12\Components64 Log.txt
Additional information may be available in the InstallLog files under: C:\Program Files\Microsoft Dynamics AX\50\Setup
=== Setup was canceled or failed. For details see the previous messages in the log.
=== Setup logging ended: 8/8/2012 4:46:35 PM ErrorLevel/ExitCode: ‘1’ ===
