HI I have installed AX 2009 in Windows server 2008. I have installed the AX 2009 client in Vista.
Whenever i am trying to open the AX in client, it says Connection with the AOS not established.
the client machine is the normal user in the Domain. I installed the client with the domain Administrator login. The AOS name and the instance name in the client configuration is given perfectly. Still am not able to run the application in client machine.
If you have installed Ax client in AOS server, is the connection working? If yes, save the configuration in a shared directory. Then from the client machine, use this configuration to connect to Ax.
