I am new to Nav, and implementing the solution for a customer. I am stuck at a point,
I am using the default barcode mask that was in NAV assigned to a variant. The ls-retail manual says that the system will create variants and the barcodes automatically
I do see the variant been created, but not the barcodes. also when i manually create barcodes for the variants I cannot use the same Item number.
Desperately need help
Thanks in advance.
