Hi Ibrahim, Fields like “[CREATEDDATETIME]” / “[MODIFIEDDATETIME]” / “[CREATEDBY]” are set by the HCMWorker table’s property sheet. But they are not showing when you check the table on the AOT. If you go to the DB level as you said, you should see them , check these
OK, WorkerSlicer is the dimension name, looks like something new, is this shipped from Microsoft or a new one built? Which cube is using this one? Can you try to process the cube from visual studio 2013? It probably could provide more details.
Reg. its MS shipped or newly built. I have to check with the person who was here before.
Reg. processing the cube in VS, I already did and the 1st screenshot from that screen.
Does the related table properties has the value Yes? Look at the properties of the table in AX.
If they are enabled, then you should see them at data base level (not in the AX, as they are system fields)
