Deploying default Cubes Ax 2012 r3 CU9 VM
hi,
im delpoying cubes in Ax 2012 r3 cu9 vm and Dynamics ps database deployes without problems,
when i deploy Dynamics initial database cubes i get:
OLE DB error: OLE DB or ODBC error: Query timeout expired; HYT00.
Errors in the OLAP storage engine: An error occurred while the dimension, with the ID of ‘SALESORDERCUBE’, Name of ‘SalesOrderCube’ was being processed.
Errors in the OLAP storage engine: An error occurred while the ‘Sales ID’ attribute of the ‘LedgerSalesOrder’ dimension from the ‘Dynamics AX initial’ database was being processed.
Internal error: The operation terminated unsuccessfully.
Server: The current operation was cancelled because another operation in the transaction failed.
OLE DB error: OLE DB or ODBC error: Operation canceled; HY008.
Errors in the OLAP storage engine: An error occurred while the ‘DATAAREAID’ attribute of the ‘LedgerSalesOrder’ dimension from the ‘Dynamics AX initial’ database was being processed.
Errors occurred while processing the Analysis Services database: Dynamics AX initial
How to fix it ?
nobody knows ?
