I want to perfom an action when i am selecting a new record in SalesLine Form. can you tell me where can i write code…?
Thanks in Advance…[:)]
One way is to override the create() method …
If you want to have some default values when you create a new sales order line - then override the initValue() method…
Hi Kranthi,
Thanks for Reply, Let me clearly tell you…
I have a form like SalesLines in Header & ProdTable in Footer (as SalesOrders and SalesLines)
now after selecting a SalesLine in Header want to get all the related Production orders in Footer.
Relation is SalesLine.SalesId == ProdTable.InventRefID
This is the requirement…
Thanks in advance
You can use DynaLink for that
Add this code to the executeQuery() of ProdTable data source before super()…
Query q;
QueryBuildDataSource qb;
q = new Query();
qb = q.addDataSource(tablenum(ProdTable));
qb.addDynalink(fieldnum(ProdTable,InventRefTransId),SalesLIne,fieldnum(SalesLine,InventTransId));
this.query(q);
