Hello all,
In have 3 tabels in my reports and I want to decide from Request Page which tabel be visibel.
Has anyone an idea?
Hello all,
Has anyone an idea?
please elaborate your question, create 3 Boolean type variable for particular table on request page then set the visibility hidden property for each table using Boolean type variable on layout. i think it’s help to you.
Take boolean variables and based on set table property on RDLC
Suppose You have 3 tables
Item
ILE
Value entry
take 3 Boolean for above 3 table on request page and set true according to your condition.
As i understood if you have 3 tables then you will create 3 tables on rdlc right?
So just set table visibility based on Boolean value
e.g. if item will be required on report then iif itemboolean=“True”,False,True .
you can use boolean values as per condition too.
While asking any query please give the detailed knowledge and what issue you are facing .
Thank you for the syntax,actually this was the question and sorry for my vague question!
its ok, happy to help . Mark your question as a resolved one
