How can we hide a section in a report in Nav 2009? Someone please help.
Hi Teena,
How about Visibilty option in RDLC?
-TR-
Can you please tell me where to find this option?
Hi Teena
place the beloe code at OnPreSection() of the particular setion
CurrReport.SHOWOUTPUT(Fales);
Jerome marshal
Yes, if your report is a Classic Report Marshal’s code will do the trick.
For RDLC, there is a property to hide or show the Report Item. The property is Visibility → Hidden. False to make it visible and True to make it hidden. You can also create an Boolean expression to specify the value
e.g: =IIF( 2 = Val , False , True). In previous example if Val = 2 then the Report Item will be visible (Hidden(False)) ELSE the Report Item will be Hidden (Hidden(True))
-TR-
