I’ve setup a ax 2009 installation with the AOS etc on one computer and then i have a couple of other computers connected to the AOS with only the AX client installed. Now i want to use the biztalk adapter in AX.
I’ve setup a computer with biztalk 2009 and i installed an AX client on the same computer but when i add the biztalk adapter feature to the ax client the installation fails. I can’t make any sense of the error log.
Do i have to add the adapter feature at the same computer as the AOS runs or is something else wrong?
Thanks in advance
