The table “user menu level” from verion 4, accidently got imported to a 2.6 database;
When a Backup is performed an error pops up.
Internal Error: 47 -1 text no. 1961-0 does not exist in the stx file.
How do I get rid of the TABLE ?
I am unable to DELETE the Table since I do not have permission; I can not renumber it;
I am unable to edit the stx file since fin.exe then reports that the checksum is invalid.
Hi
I have had the same issue in the past but I can’t remember exactly how I solved it. I think I did the following;
- Make a copy of the old version of Navision
- Open the copied old version of the Navision database with a 4.0 client (I am not sure if you can open a 2.60 with a 4.0 client, I think I had the issue with a 3.7 database)
- Make a backup with the 4.0 client.
- Restore the backup into a 2.60 database
Regards
Claus
Hi
I just tested my suggestion and it didn’t work so I tried it another way and it works:
- Make a copy of the 2.60 version of Navision
- Open the copy with a 4.0 client
- Restore the backup to a SQL database
- Close the database
- Delete the table “User Menu Level” from Enterprise Manager
- Open the table “Object” from Enterprise Manager and delete the two records
- Type=0 and ID=2000000061
- Type=1 and ID=20000000611. Re-open the database with a Navision 4.0 client and make a backup
- Restore the backup with a 2.60 client
Regards
Claus
Would it not be nice to have an open LICENSE file for things like this [:)]
because that table is not used in a system you can export it as a text file, delete all from it (except header part) and import it again?
But, I never saw 2.6v, I don’t know if it’s possible to do txt export/import…
Yes, it would. You solution center might be able to get a temporary license for you (or if you work for a solution center you could ask Microsoft your self) but it is probably faster for you to try my suggestion than wait for that.
Regards
Claus
Yes a lot like C/DART, its a graet thing, but by the time you work out the politics to get it, you may as well restore a backup, and manually re-enter the lost data.
