Error while taking backup from Navision
hi ,
When i am trying to taking backup from navision (tools → Backup),
an error occur “TableData 5928 does not exist”. I check in the object designer but the table 5928 exist.
can anyone help me??
thx in advance
Can you run that table ? It may be that your license is not allowing you to open that table or permission.
Do you have super role?
g.
hi,
when i try to run this table, i have the same error “TableData does not exist” and i am using developer liscence , and i have a super role.
check for the record variables used
u may have used a deleted table as a record variable
The easiest way to find it is to design the object, the compile it. It should take you straight to where the error is (if it is a local variable). Otherwise just check the Global variables list.
