pratha
June 20, 2008, 7:36am
1
Hi
We are not able install Nav 5.0 sp1 on windows vista business edtion
we are getting below error
" Error 1935 an error ocured during installation of of assembly component
{98cb24ad-52fb-db5f---------------------------------------"
help would welcome
Thanks in advance
DaveT
June 20, 2008, 11:37am
2
Are you installing as administrator?
pratha
June 20, 2008, 11:41am
3
yes Dave, I have tried that possibilty too. but still not able to install.
DaveT
June 20, 2008, 12:17pm
4
Try with anti-virus turned off and if still no joy try re-installing your .NET framework
Legosz
June 20, 2008, 9:06pm
5
I’ve had similar errors on XP - I found removing and re-installing .Net framework corrected my issues
w.stil
June 29, 2008, 7:24pm
6
We just went live with our Navision 5 system. We only had your error message when we used the .msi installation.
We switched to the .exe (large) installation file from cd.
(Skipping the SQL agent).
This installation overcomes several update issues on computers. And please don’t forget the cpp prerequisite.
Regards.
Wouter Stil
admin1
March 3, 2009, 8:38pm
7
After I did a fresh install of Vista I had the same problem. Neither of the above suggestions helped me.
But instead I found this https://community.dynamics.com/forums/t/9325.aspx by our member DaveT:
This is a common error when installing NAV on Vista (and Windows Server 2008) x64
The x64 Redistributable Package is not included in the NAV setup and is not included in a clean Vista/Server 2008 installation but must be downloaded and installed before installing NAV.
ReGa
March 3, 2009, 9:38pm
9
…also check the name(s) of the directory(ies) (like “CSIDE client” or similiar) there is one installer package on the road which contains a wrong directory name(s)…
admin1
March 3, 2009, 10:09pm
10
I was installing in the “normal” x86 version. Not 64 bit.
Thanks Eric. I was trying to install on Windows 7 and it wasn’t working and your link solved the problem.
Greg
zimms
April 19, 2012, 11:58am
12
how about the 64bit i have encoutered error 1935
