I’m not able to download symbols in Al code, it is showing below error, I’m using D365BC Wave 2 on local machine. below is the launch file and error.
Note : D65BC web client is working fine.
“version”: “0.2.0”,
“configurations”: [
“type”: “al”,
“request”: “launch”,
“name”: “Your own server”,
“port”:7049,
“server”: “http://localhost”,
“serverInstance”: “BC150”,
“authentication”: “Windows”,
“startupObjectId”: 22,
“startupObjectType”: “Page”,
“breakOnError”: true,
“launchBrowser”: true,
“enableLongRunningSqlStatements”: true,
“enableSqlInformationDebugger”: true
Error: Could not connect to the server. Please verify that:
- The server is started.
- The development endpoint is enabled (DeveloperServicesEnabled server setting).
- The service name matches the one specified in the URL.
- The port number matches the one specified in the URL (DeveloperServicesPort server setting).
- The protocol matches the one specified in the URL (DeveloperServicesSSLEnabled server setting), and that a trusted certificate is used in case of an SSL connection.
[2019-11-16 20:53:17.27] Error: Could not connect to the server. Please verify that: - The server is started.
