Your extension is incompatible with an upcoming release of Microsoft Dynamics 365 Business Central
Hi everyone,
I’ve received a few mails with this issue.
I have 2 reports with this issue into a customers tennant, in a cloud version.
Today, I’ve pulled a BC15 version into a docker, and fixed those reports. But when I’m trying to deploy the extension into the tenant, I get this error:
“The runtime version of the extension package is currently set to ‘4.0’. The runtime version must be set to ‘3.2’ or earlier in the app.json file in order to install the extension package on this server.”
What should I do? I understand that the tenant should be upgraded to the BC15, but hown can I do that? I msut way the 90 days I have to fix the extension version errors?
Thank you very much
Did you try updating your “AL Language” extension in VS Code? you have to upgrade it to the new version which is 4.0… and with that you can setup your runtime to 4.0
In VS code the version is correct. THe problem is that the tenant is not upgraded yet…
You should use next major version while uploading your new extension so that Microsoft will install it when they upgrade the tenant to BC wave 2 automatically.
Thanks MOhana.
Tha’t what I’ve done. Use next major update, and wait until the automatic upgrade.
