I have facing problem while downloading Symbols
I have just Install Business Central on Docker. It’s webclient works fine on local machine but not in global machine.
Also I have issue while setup with VS code. Symbols not downloading.
Please suggest answer for this.
Error: An error occurred while sending the request.
The underlying connection was closed: An unexpected error occurred on a receive.
Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
are docker services running?
Yes Web Client running& Also docker is running
Go into the Servicetier, jump to the tab Developmen and activate the Generate Symbols and restart servicetier.
I have Installed BC on docker, So am not able to find Development Administrator to check service tier
Can you please where I can activate generate symbols
check port turn of firewall and try
Firewall Already turn off
Please help me for this
download and install latest .Net framework
I dit not say that you should start something called Development Administrator.
Start the Business Central Application windows program,
In console root window to the left click on BC130
Find the fasttab Development
Click on EDIT
Enable the field: Enable Loading Applicaiton symbol references at server startup
Click on SAVE
Restart the servicetier.
Also how did you start the docker container?? You have been around for a long time so you should really know that the more information you provide the better and faster answer you get…
