I am calculating total for Qty and Line amount On Purchase Line and then putting it in text variable and displaying it .The total come correct in classic report. But when I convert the report in RTC the value for the text variables are not shown .Any one knows why this is happening ?
Thanks in advance
Did you check in dataset results?
Yes I did .I also taking the Vendor Name form vendor table in text Variable and it works fine in same report .But it didn’t work for Totals
Can you show your classic layout and datset results(total qty)
where (in which trigger) did you calculated the value?
this is not the dataset result…
Search forums to know about dataset results…
Why did you use FIRST() ? in rdlc report?
remove it and try…
