hi frndz,
I having problem in R2 rtc report ie it is not showing amount in words but it is showing amount in words in classic report.
what should I do for showing amount in words in RTC.
hi frndz,
Where did you write code in report?
If it is in sections then you need to move it to dataitem triggers…
Dear Rahul,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
