I don´t really know if this is the correct forum for this question, but when you are desperate… I have to “cheat” a Navision client located inside a Windows 2000 Terminal Server to redirect data sent to the Terminal Server´s local COM port to the client´s computer COM port, so it can print invoices locally to a printer that´s connected to the client´s computer COM port, but to which Navision communicates through an OCX. Terminal Server has an option to capture a device connected to a local COM port, but Windows does not recognize this printer, and therefore it does not share the printer inside the Terminal Server window. Any help will be appreciated…
I don’t think you can do direct serial port redirection i TS (yet) as you can with Metaframe. You can take a look at www.ncd.com. As i recall they have a solution. Regards
