Terminal Server
Ok…what’s the trick to get Navision to run multiple sessions on Terminal Server? We’re using Terminal Server 2000…and yes, I’m a novice.[:I] Does it require an “Application Compatiblity Script”? If so, does anyone have one? Thanks…
You need a special installation script which our NSC can get for You. Otherwise Navision wont run properly. Otherwise it’s no problem as long as You specify TEMPPATH and ID in the startup command that Your users use to run Navision. Should look like this: “c:\Program Files\Navision Attain\Client\fin.exe temppath=c:\temp, id=c:\zupfiles%username%”. Make sure everyone has write, read and modify in the specified directories. //Lars
Thanks Lars…appears to have done the trick
