TDS rounding
There is a problem of calculating TDS on invoice.
Currently system is deducting TDS invoice line wise. So if there is a rounding of “1” and and “nearest” rounding then system is not calculating TDS for values below 0.5.
And it creates a problem in TDS calculation.
Is there any way to calculate TDS based on total invoice value and not on item line wise.
Jainal
Hi Jainal,
Did you ever find a solution to this problem? If yes, would you mind sharing it with us?
