TDS Not calculated
hi,
User have select the TDS option but after posting invoice, TDS amount hasn’t calculated. Kindly suggest how to correct that TDS entry. If its through TDSAdjustment Journal, then how to do that process.
Hi
Did you ever find a solution to this problem? If yes, would you mind sharing it with us?
