Rounding Problem
Could you share the what parameters do i need to define to round the amount in the Purchase Invoice / Sales Invoice.
For example:
Line amount - 1000.48 ( This should not round )
Tax amount - 44.15 ( This value should round to nearest value)
Total value - 1148.03.
When i post the Purchase / sales Invoice Inoivce then system should round the value to 1148.00
To achieve the value what setup i need to do?
Hi Pioneers,
Please help me to solve the problem.
Thanks in advance.
check it out following links
http://dynamicsuser.net/forums/p/26194/142319.aspx
http://www.mymibuso.org/forum/viewtopic.php?f=23&t=28651&start=0
Thanks for suggestion.
It doesnot work to my scenrio.
What I am asking is there any standard solution is availble.
what you exactly want can you please tell me so i can try on my side and get back to you. I didnt get your first post.
Hi Hansika,
Here is the solution for your query.
There are many possibilities for rounding like >,< and =.
Like wise you have to give precision for rounding and direction of rounding which is Less than ‘<’ or greater than ‘>’ and Equals ‘=’
Go through the example below you will understand the utilization of rounding function.
RequiredNumber := ROUND(Actual Number,[Precision],[Direction]);
Eg:-
AmountToRound := 1148.03; //Assignment of value to a variable.
Amount := ROUND(AmountToRound,1,’=’); //Actual rounding goes here.
MESSAGE(‘Rounded amount is %1’,Amount); //This is to check the value after rounding.
