i need to retrieve the highest (integer!) value and increment by 10. It took me a while to figure out that it is sorted (10,100… and not 10,20,…,100) that’s why the following code breaks:
SELECT maxof(myString as int) FROM myTable;
this code will retrieve 40 and not 100.
Question: what can I do to get the 100? In sql you could use order by cast (myString AS int) but i do not get this to work in AX
you can’t. So either you change the field to integer or do a workaround like you already did. I’ve seen a workaround to a similar situation where the value of the string (‘10’) is replicated in a LineNum(10,000…) field and the LineNum is then used in ordering the records
You can store the values into the Set collection class and use SetIterator end() method to move the cursor at end and retrieve the last value from it. Since set will sort the values automatically during insertion.
your response answers my question but I can not use it for my purpose. I need to apply the solution on a table and the set collection can only store one field with multiple values (as far as i know)
i need to:
Sort by myString
find the hightest number
return myString2
myString mystring2
10 aaaaa
100 bbbbb
20 ccccc
30 dddd
40 sklfjsdklf
→ record with the highest numeric value is 100 (not 40). return value needs to be “sklfjsdklf”
have a look at my initial post (posted on Tue, Oct 23 2012 23:19). A string and a value is sorted differently (i guess it depends on the sql coalition… but in my case i can not change that anyways).
