while assigning like this am getting error…
int i;
i=select maxof(Rno1) from tempcol;
Rno also int type,
wat s the pblm, pls anyone help me…
thanx
int i;
Rno also int type,
thanx
select maxof(Rno1) from tempcol returns a table buffer and that’s not compatible with the int type. You have to specify a field, e.g. i = (select maxof(Rno1) from tempcol).Rno1;
Hi
how can u assign select statement to a variable., this is syntax error …
select statement never returns a value directly…thru table name you can get a value…
you can modify ur code like this…
i=(select maxof(Rno1) from Tempcol).Rno1; → Tempcol is a table name not a buffer name…
hi Martin,
i tried as per ur example, now also am getting error
the tempcol does not exist
wat s the pblm
thanx
The select uses the table name, but I don’t know the type of “tempcol”, you’re the only one who knows it.
Anyway, look at this example using standard AX objects:
int level = (select maxOf(InventLocationLevel) from InventLocation).InventLocationLevel;
