Is it possible to have the maximum string length of a field in a select
Something like : select maxof strlen(itemid) from inventtable
not possible syntax error on strlen
regards,
Thomas
the SQL statement is select max(len(itemid)) from inventTable
then you can try to execute through x++ with something like that
Connection Con = new Connection();
Statement Stmt = Con.createStatement();
ResultSet R =Stmt.executeQuery(‘select max(len(itemid)) from inventTable’);
while ( R.next() )
print R.getString(1);
then you’ll probably have to manage permissions
regards,
Thomas
