I need to send mail to multiple to address not CC/BCC.
Using SysMailer
-To address come from Table
Now i could send mail to only one person, using hardcore the mail address
Waiting for your reply
Jeevanandham
Using SysMailer
Jeevanandham
What does that mean? Can you please explain or show us the code?
static void SendEmail(Args _args)
SysEmailParameters parameters = SysEmailParameters::find();
SMTPRelayServerName relayServer;
SMTPPortNumber portNumber;
SMTPUserName userName;
SMTPPassword password;
Str1260 subject,body;
InteropPermission interopPermission;
SysMailer mailer;
System.Exception e;
OEMImportConfigurationTest OEM;
List toAddr;
ListEnumerator lenum;
str toAddress = OEM.Email;
if (parameters.SMTPRelayServerName)
relayServer = parameters.SMTPRelayServerName;
else
relayServer = parameters.SMTPServerIPAddress;
portNumber = parameters.SMTPPortNumber;
userName = parameters.SMTPUserName;
password = SysEmailParameters::password();
subject = “Subject line for the email”;
body = “Body of the email”;
CodeAccessPermission::revertAssert();
try
interopPermission = new InteropPermission(InteropKind::ComInterop);
interopPermission.assert();
mailer = new SysMailer();
mailer.SMTPRelayServer(relayServer,portNumber,userName,password, parameters.NTLM);
//instantiate email
mailer.fromAddress(userName);
toAddr = SysEmailDistributor::splitEmail(OEM.Email);
lenum = toAddr.getEnumerator();
lenum.moveNext();
while(lenum.moveNext())
mailer.tos().appendAddress(lenum.current());
//mailer.tos().appendAddress();
mailer.subject(subject);
mailer.htmlBody(body);
mailer.sendMail();
info(“Email has been send!”);
catch (Exception::CLRError)
e = ClrInterop::getLastException();
while (e)
info(e.get_Message());
e = e.get_InnerException();
info (“Failed to Send Email some Error occure”);
Trying this code now but how to fetch to address from table
OEM.Email field consist the data like " abc@xy.com,asd@xy.com,sdf@xy.com "
from this data i need to split those three mail address and need to send mail for those three mailid
https://www.tech.alirazazaidi.com/sending-email-using-x-code-dynamics-ax-2012/
This two links i followed…
if you look at this method SysEmailDistributor::splitEmail, the splitter used is semi colon. You can use the code, but the splitter as comma.
emailAddresses = strSplit(_email, “,”);
Thanks kranthi, ill check and update
Below job is working fine with multiple ToAddress with attachments
SysMailer mailer;
System.Exception e;
List toAddr;
str toAddress = “abc@xy.com,asd@xy.com,sdf@xy.com”;
str filePathName = @“C:\Path\filename.xlsx”;
else
subject = “Testing mail”;
try
//instantiate email
toAddr = strSplit(toAddress,",");
mailer.attachments().add(filePathName);
mailer.sendMail();
while (e)
info (“Failed to Send Email some Error occur”);
